I have a 2002 Hyundia Sonata V4, 190K (Mostly Highway) and its burning oil I need to add a quart like every 2-3 weeks, Im running Royal Purple 5-20 then switched to Royal Purple 10-40 and it seemed to help a little, Im also using both KN Oil/Airfilters. It seems from what I been reading Royal Purple has been the wrong choice for this application, more suited for short term drain intervals and performance. Also been reading up on autoRX and mabye using that with Castrol High Mileage 10w40.
I guess while im here I should ask about my other vechiles I also have a 2006 F150 60k, just change the plugs battery trans fluid, running royal purple 5-20 changed every 10k with KN filters. This truck does mostly highway but I pull and haul tons with the truck, I have a liftgate installed and its not uncommon to have 500lb of load on this truck. It sometimes can site parked for a week or two. Im considering switching to AMSOIL.
Would you guys recommend a autoRX application for a truck with this mileage, I did seafoam the truck at 60k aswell and added redline fuel injector cleaner to all three cars.
And lastly I have a 2006 BMW 330i 40k on the clock, been following BMW Service Schedule, with there 15k drain intervals and filters, basicly take it to the dealer for free maintenance for 4 years 50k when the service light comes on. The oil they use is BMW Branded Castrol Based 5-30 this is the stuff the dealership uses....
http://www.trademotion.com/partlocator/i...&catalogid=4462
Well NOT exactly 15K BMWs have a oil CBS condition based sensor that can shorten or extend this depending on how the car is driven for more on this https://bobistheoilguy.com/forums/threads/bmws-condition-based-service-system.84476/
And on there website they list the following bmw approved oil alternatives
http://www.bmwusa.com/Standard/Content/Owner/SyntheticEngineOils.aspx
"The oils listed below meet BMW's Long-life rating and are acceptable for use in BMW Passenger vehicles and SAVs in the US market with gasoline engines.
BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market:
•Castrol Syntec European Formula SAE 0W-30
•Mobil 1 SAE 0W-40
•Pennzoil Platinum European Formula Ultra SAE 5w30
•Valvoline SynPower SAE 5w30 (This isnt the over the counter version)
Use only oils with an API rating of SM or higher.
The choice of the right SAE grade is based on the climatic conditions in the region in which you normally drive your BMW."
But free maintenance is going to end soon and Im going to be doing my own oil changes at every 10k and want to switch to something better, I want to keep this car forever....
Car is driven daily 50 miles city, M-F, weekends I might track the car redline the [censored] out of it. So I was considering Royal Purple new Euro Blend, or Redline with BMW filters. Not sure on DD protection by doing this.
Thanks in advance for all your guys help!
•Mobil 1 SAE 0W-40
