What 0W20 oil is it that the dealers are using?
Honda does recommend 5W20 oil; my source is my 2003 owner's manual.
Are you sure the M1-104 filter is too restrictive? The synthetic media is suppose to filter down to a small size while still maintaining flow.quote:
Originally posted by Bror Jace:
Avoid Mobil 1 in high-RPM applications. Too restrictive.
--- Bror Jace
Dont get a fram filter. Get a wix, bosch, STP, supertech, etc anything but a fram.quote:
Originally posted by Captal:
Well I picked up some Mobil1 5w30 at Walmart today- $22 for the 5 quart. It was the exact same price as buying 5 individual quarts
I didn't pick up a filter- there was the normal fram, double guard and another fram filter that was more expensive. They were $3,$4,$7 respectively. I wasn't sure which one to get- I know the "normal" one isn't as high of quality, but I didn't know if the $7 was worth it. I'll try to just go to a car store and pick up something better, even though I'm not sure what to get.
I have a 4 cyl 03 Accord but I'm sure the V6 is similar. Some oil will come out after you remove the filter. This is in additional to any oil you may spill from within the filter. This is because the anti drain back valve in the filter will keep oil in the block going up to the heads. Gravity causes the oil the spill once you remove the filter containing the one-way valve. However, this is not that much oil and you should not lose any oil in the oil pan.quote:
... By the way doesn't the oil come out if I take the filter off? My filter is pretty low on the car, by the passenger side wheel.
The 2003 uses a smaler filter but the biger 2002 oil filters listed for the 2002 should fit. At least it does on my 4 cyl. The M1 oversize filter is the M1-104. I don't know about the 3323.quote:
Also- autozone didn't have a 2003 catalog so my car wasn't listed- is the 3323 the correct filter for my car? Mobil1 M-110 was listed as fitting my car, I can't find anything online either...
Yeah the thread size was definetly bigger for the filter listed for the 2002. How would a bigger thread size actually fit? Will the 3323 fit just because it's the same size as the M-110?quote:
Assuming you are talking about the ASL, there is no question in my mind! I would take the Amsoil.quote:
Another question- if you could get Amsoil 5W30 for the same price as Mobil1 5W30, which would you buy?
