I thought I would post these tidbits for some that do not understand the effects of debri in the engine oil and using too thick of a engine oil for the ambient temp . You will also see that Melling and other manufactures advise using a heavy duty aftermarket pump drive when using any of their High Volume gear to gear oil pumps . The reasoning is not Vi related initially but is due to the additional torsional flex caused by the 30% larger gears . Enter a heavy wt oil and the problem multiplies due to this particular design which has no means to support the gears at the botton end of the pump . Even the stock pumps can and do suffer torsional flex internally and eventually wears the pump rotor housing and end plate as seen here . This type is gear driven off the camshaft and turns 1/2 the engine speed .
pump wear
Here in figure 1 you will see a picture of a Gerotor style oil pump thats driven full engine speed off the crankshaft . It's used in the LS1 , GM 3800 and many Fords along with other makes .
Gerotor
These pumps will not wear as badly when too thick of an oil is used generally because they do not have the support problem the figure 2 design pump has .
The better engine builders blueprint the gear type pumps to reduce internal cavitiation and tighten up the end plate clearance . I've seen as much as .004 gear to endplate clearance in these type pumps ... too much but an easy fix .
Abrasives in the engine oil lead to premature pump wear as well especially since many engine now come with soft aluminum housings instead of the cast iron which are a bit tougher in terms of durability . The GM 4.3 is an example of a engine that uses an aluminum oil pump housing w/ gear to gear type oil pump . These used a bronze bushing in the pump housing to support the main internal gear shaft thats ran by the drive that meets the distributor .
Distributors can and do suffer some of the same torsional stress but to a lesser degree if it's the type using a non-sealed bushing in the lower part of the distributor housing and is fed by pressurized oil .
When an oil pump gets worn an engine has a problem . Usually the top end " hydraulic lifters " is still tight but the oil pressure is low making for the need to run a thicker oil to gain some oil pressure back but the lifters don't much like it as evident by both cold start noise and the viscous caused clack that various in severity due to the thick oil even when at hot idle.
I always thought it funny to see an engine builder give a bottom end race clearances then run hyperuetectic pistons and flat tappet hydraulic lifters ... kinda screws with the oil choices in a streeter .
but that deserves another topic .
Anyway cleanliness is godliness to a good engine builder ,
Keep good oil filters on those engines and keep them internally clean by whatever means available !
Ask Terry Dyson about how a clean engine benefits in terms of lenght of time it will last as opposed to an identical engine that's ..... filthy . Even the merits of keeping the ring pack clean and moving freely effect how long the lower end can last and that includes the oil pump
[ March 07, 2004, 08:54 AM: Message edited by: Motorbike ]
pump wear
Gerotor
