On the forum I see a lot of discussions or sometimes passionate debate on which oil brand to use, which viscosity, the perfect OCI, what you can deduce from a UOA, and etc.
However, I can't seem to find much on what an oil pump does to engine wear or in fact a weakened oil pump. Perhaps I just did not look far back enough.
My question is, engine oil requires the oil pump to reach different parts of the engine. The oil flow has to overcome the gravity and viscosity. The kinetic energy has to come from the oil pump to provide oil flow.
If as the oil pump ages and does not provide the specified oil flow or oil pressure, does it not incur more engine wear?
I think there is a difference between flow and pressure, I don't mean to use these two attributes interchangeably. I don't want to get an PhD or read two hours of Wikipedia before posting this question, so my apologies if this confuses you.
