Vehicle is a 1997 Dodge Ram 360 (5.9 gas). Vehicle has 198,000 miles. I am the original owner and have changed oil every 3000 miles since new. Right now, the current oil has about 2000 miles on it, and it still looks clean on the dipstick, so sludge shouldn't be an issue. About 50,000 miles ago, the oil pressure, when at a warm idle, began to be noticeably lower on the gauge than it was when new. Yesterday I finally changed the sending unit with an OEM one from my Dodge dealer, but the issue persists. The gauge also "jumps around" a very slight amount. Often though, once I am cruising at speed the pressure reads as high as it ever did (approximately 40psi). The truck is all original and is in excellent shape, so I want the engine to last another 100k. The oil pan has never been removed, but I'm thinking of replacing the oem oil pump with a high volume one, to compensate for the internal bearing wear. Thoughts?
