Originally Posted By: larryinnewyork
Oil Pressure / Engine Wear at Start Up:
A person (not myself) buys a 1967 Chevy Pickup Truck.
Engine size is unknown but was probably rebuilt some what over the years.
* This vehicle will sit for 3-4 days without being driven.
This person wants to install an Engine Kill Switch.
Purpose: So he can crank the engine to build oil pressure 'before' the engine starts.
Then, turn off Kill Switch and start engine with (surposidly) better oil flow.
Question: Generally speaking, would this help prevent any engine wear.
Thanks for any responses.
This person refuses to own / repair the newer vehicles driven today.
Your question is.
Would this help prevent any engine wear?
With the emphasis on the "any" part of you question.
The answer is.
It will probably prevent "some" engine wear, but not enough to ever measure in your entire lifetime.
It really depends upon a great many factors.
The biggest advantage the kill switch will have is in the event the engine is sitting for an extended period of time between start ups, with the icing on the cake being the eventual cold start occurring in very cold weather/ambient temps.
I don't think sitting for 3-4 weeks would be a problem, let alone 3-4 days between start ups.
The vast bulk of the "start-up" wear that occurs is in the actual warm up phase of the engine, and after the engine has fired into life, but before it reaches full operating temp.
In terms of engine wear reduction for a vehicle that's driven on a regular basis.
There is a two pronged approach which is likely to be the most beneficial.
You will be much better off, paying attention to the oil quality/formulation, and to also consider the engine manufacturers recommendations in terms of oil grade.
Also to consider a reasonable warm up period before driving off, and go easy on the engine until it's actually up to full operating temp.
Ford did a study on engine wear a very, very long time ago.
Basically the study was somewhat limited in scope, but it was fairly conclusive in only one regard.
The study revealed that there was a measurable amount of increased engine wear, when an engine has a coolant temp which was
There's absolutely nothing more that's conclusive to be drawn from that study.
As far as I know, there's no further information available on the matter.
I think short trips are murder on an engine and the oil.
Anything below a distance of 10 miles/16 kms is deemed to be severe service. And for good reason.
It's more important to bring an engine up to temp before driving it harder than normal, and to keep it at operating temp as much as practicable.
It's the reason why taxi's and heavy trucks go so long in service before wearing out their internal components.
The quality of the engine oils available to us today are outstanding compared to way back when Ford did their study.
