Oil pooling in intake manifold, 3800, 95, Olds
Alberta, Canada
Hi,
1) Subject = '95 Olds, 3800, Series II engine.
2) Last fall I changed the lower intake manifold gasket at 70,000 miles.
3) I noted two oil pool; one on the passangers side, back corner, and the other on the drivers side front corner. I changed the plenum gasket, but not the plenum.
4) Because the plenum was a bit warped, and due to the "EGR burn through problem", I decided to change the plemum. I did this last week, and noted the same two oil pools.
5) The intake manifold passages are wet, that is, are coated with oil.
6) I bought the car last fall, only to find that it cosumes approx. one liter of oil in 2500 miles.
7) First Question: Is this pooling of oil in the manifold normal for these engines?
8) Second Question: Could this be where my oil is going? The engine is not leaking oil, and there is no visible smoke. The oil can only get to the combustion zone (A) through the rings (B) down the valve guides, or(C)through the PCV circuit.
9) It seems like a bumb design, another GM fumble of the ball. For decades engines have been designed with PCV circuts that do not trap or pool oil. The flow of the air into the crankcase and out again is designed in a way that permits any excess oil to flow back to the crankcase.
10) I had a '94 Olds, Series I, 3800 that at 135,000 miles, would not consume a liter of oil in 7000 miles. The PCV valve on my '94, 3800 was located near the throttle body, and I never had the Plenum (aluminum) off the see if there were puddles of oil in the manifold. Perhaps there were!
10) I put on a Dorman plenum with the inproved EGR tube fix. I noted that the Dorman plenum had a somewhat smaller hole just below the PCV valve. The original hole was approx. 0.315 inch dia. and the Dorman PCV entry hole dia. was approx 0.220. I wonder if this was done intentionally, to reduce the flow in the PCV circuit.
11) Third Question: Do these engines have ring coking (carboning) problems as does the 1.9 liter Saturn engine. I read that the 3800 went through two ring tension reductions; one approx '88, and another approx. '93. Also the piston was shortened along with the connecting rod in the Series II engine. It makes me wonder if the engine designers have not gone to far in their attempt to squeeze more efficiency out of these engines, at the expense of reliability and life. For its size, and powere, the 3800 definitely gets good mileage, and is noted for such.
Thank you
Porterhouse6
Hi
Rest easy about the oil pooling on the corners of the LIM. Its completely normal. As for the UIM, I always use the APN UIM which combines a reduced diameter egr chimney with a sleeve in the UIM.
After nearly 100,000 miles on several of these, no problems, no warpage at the TB.
Install a catch can in your PCV line.
Cheap , easy, and it works.
It attenuates deposits a lot.
[you have to manually dump the reservoir]
Hi mechtech2,
Regarding the installation of a "catch can", I can't see how that is possible in this PCV design. The porting is all internal to the lower aluminum intake manifold and the upper plastic plenum.
I suppose it is possible to replumb a new PCV circuit similar to the older V8 ones, but the pooling would still happen I think. The pooling seems to be inherent to the lower intake design. That is, it has low spots in it where pooling can exist.
Porterhouse6
Porterhouse6
Installing a catch can is not possible with this design.I also used an APN plenum with reduced EGR chimney and had a couple of small oil pools,it seems normal.
I'm thinking sticky rings are a possibility,while the saturn is an extreme case all engine tend to get some deposits in the ring area,its just the nature of the beast.I would run a qt of MMO next OC and use 10w-30 just for the MMO run because of thinning.
Run it a full 3K OCI then go back to the normal 5w-30.
AFAIK the redesigns of the pistons have had no ill effects on this engine,they run forever with little problems except for the LIM gasket and plenum EGR chimney which you already took care of.
