2003 chrysler voyager with 2.4 L four banger 50,000 miles
My GF taook her van to get oil change at herusual local repair facility. They told her needed new oil pan because pan was stripped. She told mgr that they always did the oil changes they must have stripped it. She has receipts and manager looked up her records and confirmed they did all the changes .He told her it is common with aluminum drain pans. The refused to repair pan or release vehicle cost her 300 to replace pan.
After the fact she tells me. I think she should write her credit card to reverse charges because they damaged the pan and should be responsible because.
1. No crush ring ever replaced during oil changes. Not listed in parts on any of the oil change they performed. improper procedure?
2 They did the previous oil changes documented
3. I looked at new pan on internet and appears to be stamped steel ,not aluminum, [censored]? Can someone confirm?
What should she do.
What should she do.
