Originally Posted By: Starman2112
Not sure how likely this is, but the concern I would have is if the pan gets dented on the outside it could result in cracked coating on the inside. Can't imagine this would be good for the oil pump if some coating broke loose.
I doubt that would be an issue. Powdercoating really adheres to the surface it's on. Even if it did flake a little, it would be caught by the oil pickup screen, or filter, and drain out at the next OCI. If you're really worried about denting the oil pan in the first place, you have greater things to worry about. Don't worry about it! It looks nice by the way.
