Oil needs for Florida are no different?
Originally Posted By: CROWNVIC4LIFE
Originally Posted By: LT4 Vette
FL isn't too hot or cold, just stick with the factory spec oil.
+1
HHarley....How many times do we have go threw this with you?
Harley, I think you're overthinking this man, it's just oil! Use whatever your manual states and be happy
I know plenty of people who use 5w20 here in Phoenix with ZERO oil related issues. My brother used 5w20/5w30 in his F150 sold it with 200K. Another brother of mine has an '07 F150, all 55K miles so far on 5w20. Truck runs really well.
Originally Posted By: Ken2
I looked at some temperatures for Gainesville, just a guess at a location in northern Florida. It shows average summer max around 90°F, which isn't too bad (ignore the discomfort of humidity for machinery). While 5W-20 is probably OK, depending on how long I planned on owning that car, I'd choose a heavier viscosity, probably a 10w30 for that climate and a 5W-40 for a very heavily worked truck.
Quote:
A properly running car should run at the same operating temp in Florida as it does in Alaska.
WHICH operating temperature? The coolant in the heads?...yes. The coolant leaving the radiator headed to the bottom of the cylinder water jacket?...no. The oil in the oil pan surrounded by ambient air?...no. The oil elsewhere in the engine?...depends on how hard the engine is worked.
Jacksonville.
+1
Bottom line just use what your car calls for no matter where you live. Period.
With almost 900 posts you should know that by now.
I know some manuals will get extremely "picky" and spec multiple weight oils, depending on the "outside temperature" of where you will be driving "during" that fill of oil....
Then others, state plainly on the oil filler cap, which oil weight to use, K.I.S.S.
I love it; makes it so much easier.
Granted, the oil filler cap-noted weight should be OK for year round usage, or I don't think they would list it on the cap in the first place
Most vehicles should do fine with a 5W-20 or 30 oil....though I do know some Mitsubishi's are "picky" and will call for a 10w30 or 10W-40 even....
My rule of thumb, is go with the lightest weight oil possible spec'd in the manual for better flow-ability and protection
Yeah, im sensing this.
Thing is, people ALWAYS used to say "Heat thins Oil."
I guess thats not true.
FORD4LIFE why did you change your name from CROWNVIC4LIFE?
Also.. Work is going very well. I need to get a hold of A car, or MY car, next year. or i am going to go insane and start drinking Oil and trying to dive in to my engine to see the Oil spewing around inside.
I hope it does not get that bad. I need a car to mess with. All messed up, missing parts.. Gimme. Ill replace em.
5W-40 and 10W-40 Group IIIs sound like good oils. 5W-50 and 0w50 seem not necessary. Unless i get a Ford GT, 2007-2010. Then im following Spec'd oil.
And yeah, those Manufacturer charts ARE confusing!! They say 20w50 over 50 degrees, then 10W-40 goes down to like "10 degrees" then 10w30 AND 5w30 go from -32 (on 5w30 LOL or so) to "86 degrees" ??? and 10w30 is from -10 to "95" (?)
Every Honda i ever had that takes 5w30 i always wondered if i should go UP a grade in 105-degree July heat. 10w30 was always the answer. As 5w30 in a Honda CRX.. maybe even then 5w30 is fine. I am not brave enough for xW-20.
If you had a Honda CRX would you put 5w30 in it? And skip 10w30? A bigger V6 like a 3800 or even a 3.1, maybe 10w30 is better.
OK thats my release for tonight. i work at 5AM. Goodnight. Thanks!
If it specs 5W-20... Use 5W-20. I tried 5W-20 in my cavalier that specced 5w30 and it seemed to work fine for a while... Then there was noise. Then the oil pump died. Whether or not the oil pump was related, we'll never know..
And I'm pretty confident that Ford4life and crownvic4life are two different members.
