I have a hand pump, its a tube with a piton inside with a handel on the end of the rod and a hole on the end to suck in, or to push out fluid. I used it to refill trannys and diffs. so what is it called , and where can I get another one? Thanks
oil hand pump? Handheld suction pump? You can get a few types of this kind of device cheaply at Harbor Freight. They have these black tubed ones that hold about 1qt fluid and are cheap. Mityvac and others make vacuum devices too.
