oil pan 4
Thread starter
I found a longer one.It does take a while. That looks gritty.
I suggest you join an Explorer Sport Trac forum and Ranger forum because they're likely to know of 1 or 2 longer filters that are compatible with 2010 Sport Trac. If you're lucky, you might have a couple of upgrade size choices, such as a ⅓ longer choice and a ½ longer choice.
Buy the longest compatible filter that you have enough clearance for. Buy a filter with fine filtration with 99% @ 20-25 microns filtration.
NAPA Gold is my favorite fine filtration filter because (according to filter dissection video I saw) it has more filtration material and pleats per length of filter. So it's a better filter in standard size/length, and evenmoreso if you find a compatible longer filter.
If you find a longer filter, it might hang lower where a flying rock or stick could hit it. Yes, a stick. I live in a rain forest where branches sometimes fall on roads. If you drive on gravel roads, gravel can hit a filter.
So you want a thick (tough) can. NAPA Gold filters have thick cans.
An vehicle specific forum (if it has active members) can conveniently provide you a lot of vehicle specific information, especially about common upgrades such as longer filters. Ranger owners can be helpful because they're into upgrades and Rangers (of similar model years) use same filter as Sport Trac.
Searched all wix 22x1.5mm filters.
Turns out there's just not a huge selection of 22x1.5mm filters with oring diameters that will fit on passenger vehicles.
