Bitog friends,
So i have traded in my '01 VW Lupo GTI for a 60k mile '07 Seat Leon Cupra, amazing car to drive.
Managed to get in contact with the previous owner, who told me that he replaced the engine ( blown because of a broken spark plug ) @ 30k. the replacement engine is from a MK6 GOLF R20, engine code CDL. the R20 engine had 6k miles on it when it was swapped.
The CDL engine has different, stronger Pistons, rods, cams and other components compaired to the normal TFSI 2.0 engines. This engine is also found in the Audi S3, Seat leon Cupra R, Audi TTS, Golf GTI ED35 and Scirocco R.
Engine mods are: Autotech high pressure fuel pump, Full milltek turboback with 3 inch downpipe with 200 cell cat, HG motorsport intake. HG motorsport turbo outlet, BSH revamp PCV blockoff plate, Audi S3 intercooler.
Too bad i found out she uses quite some oil. 1 quart every 800-1000 miles. Going to check some things out friday ( Valve covers known to be faulty ) hopefully it isn't the turbo seals. I don't think it will be the piston rings because the CDL engine has improved pistons without the fauly rings.
Changed the oil out 600 miles ago with Total Quarts 9000 5w40, what i still had left from the lupo.
Want to change out the oil within 2000 miles to give the engine a bit of extra cleaning, but first want to find out the cause of oil usage, will do compression test if i can't find anything.
I have made a list of oils that are approved and i can get fairly cheap, please help me decide! and if you have any tips about the oil consumption, please share them with me.
0w30
Shell 0W30 AV-L
Spezifikationen und Freigaben: ACEA C3; VW 504.00 / 507.00
Castrol EDGE 0w30 TITANIUM FST
Spezifikationen & Freigaben:
ACEA C3
API SN
BMW Longlife-04
dexos2®*
MB-Freigabe 229.31/ 229.51
Renault RN 0700 / RN 0710
VW 502 00 / 505 00
(*GM dexos2®: ersetzt GM-LL-B-025 and GM-LL-A-025 : GB2C0923082)
Mobil 1 ESP 0W-30
Spezifikationen / Freigaben
Mobil 1 ESP 0w30 erfüllt oder übertrifft die Anforderungen von:
ACEA C2, C3
Mobil 1 ESP 0w30 hat von den folgenden Herstellern Zulassungen/Freigaben:
BMW Longlife-04
MB-Approval 229.31
MB-Approval 229.51
MB-Approval 229.52
Shell Helix Ultra ECT C2/C3 0W-30
Spezifikationen, Freigaben und Empfehlungen
ACEA C2/C3
API SN
Volkswagen VW 504.00/507.00
Mercedes Benz MB-Freigabe 229.52, 229.51, 229.31
Erfüllt die Anforderungen von FIAT 9.55535-GS1 und 9.55535-DS1
Porsche C30
Total Quartz 9000 Energy 0W-30
ACEA A3 / B4
API SL / CF
Mercedes-Benz MB-Freigabe 229.5
Rückwärts kompatibel:
Mercedes-Benz MB-Freigabe 229.3
Volkswagen VW Volkswagen VW 502 00 / 505 00
0w40
Mobil 1 New Life 0W-40
Mobil 1 New Life 0W-40 erfüllt oder übertrifft die Anforderungen von:
API SN / SM / SL / SJ
ACEA A3 / B3, A3 / B4
Nissan GT-R
AAE (STO 003) Group B6
Mobil 1 New Life 0W-40 hat von den folgenden Herstellern Zulassungen:
Mercedes-Benz MB-Freigabe 229.3; MB-Freigabe 229.5
BMW LONGLIFE OIL 01
Volkswagen VW 502 00/505 00
PORSCHE A40
AVTOVAZ LADA cars
Mobil 1 New Life 0W-40 wird von ExxonMobil für den Einsatz in folgenden Anwendungen empfohlen:
API CF
VW 503 01
SAAB
OPEL GM-LL-A-025; GM-LL-B-025
FIAT FIAT 9.55535 - M2
FIAT FIAT 9.55535 - N2
FIAT FIAT 9.55535 - Z2
Shell Helix Ultra 0W-40
Spezifikationen& Freigaben:
API SN/CF
ACEA A3/B3, A3/B4
MB-Freigabe 229.5, 226.5
VW 502.00/505.00
Porsche A40
Renault RN0700, RN0710
Erfüllt die Anforderungen von Fiat 9.55535-Z2
5w30
Castrol EDGE 5w30 LL TITANIUM FST
ACEA C3
Mercedes Benz MB-Freigabe 229.31 / 229.51
Porsche C30
Volkswagen VW 504 00/ 507.00
Mobil 1 ESP Formula 5w30
Mobil 1 ESP Formula 5w30 besitzt die Freigaben der nachstehenden Hersteller:
BMW Longlife 04
Mercedes-Benz MB-Freigabe 229.31 / 229.51
Volkswagen (Benzin/Diesel) 504 00 / 507 00
Porsche C30
Chrysler MS-11106
Peugeot/Citroën Kraftfahrzeuge B71 2290
B71 2297
AVTOVAZ LADA cars
Mobil 1 ESP Formula 5w30 erfüllt oder übertrifft die Anforderungen von:
ACEA C2, C3
API (erfüllt Motoren-Testanforderungen) SM / SN
JASO DL-1
Mobil 1 ESP Formula 5w30 entspricht gem. ExxonMobil folgendem Qualitätsniveau bzw. wird für folgende Anwendungen empfohlen:
API CF
Volkswagen (Benzin) 502 00 / 503 00 / 503 01
Volkswagen (Diesel) 505 00 / 505 01 / 506 00 / 506 01
Alle VW-Motoren mit Ausnahme von Pumpe-Düse-TDI ohne Longlife Service und ohne DPF zwischen 1999-2003 und R5/V10-TDi vor dem Modelljahr 2006
Total Quartz Ineo LongLife Motoröl 5w30
Freigaben:
ACEA C3
VW 504.00/507.00 (universal oil for Volkswagen, Audi, Seat, Skoda)
BMW LL-04, Backward compatible with BMW LL-01 (for BMW, Mini)
MB-Approval 229.51, Backward compatible wirh MB-Approval 229.31 (for MB,Smart)
Porsche C30
5w40
Castrol EDGE Turbo Diesel 5W-40 TITANIUM FST
Spezifikationen:
ACEA C3
API SN/CF
Freigaben:
Volkswagen VW 502 00/ 505 00 / 505 01
BMW BMW Longlife-04
Mercedes-Benz MB-Approval 229.31/ 229.51/ 226.5
Ford Meets Ford WSS-M2C917-A
Renault RN0700/0710
Fiat Meets Fiat 9.55535-S2
Opel GM GM dexos2 (rückwärtskompatibel zu GM LL-A-025 oder LL-B-025)
Total Quartz 9000 Energy 5W-40 ( current oil )
Spezifikationen/Freigaben:
ACEA: A3/B4
API: SM/CF
MB-Approval 229.5 rückwärts kompatibel 229.3 + 229.1
BMW LL01 rückwärs kompatibel BMW LL98
VW 502.00/505.00 rückwärts kompatibel VW 501.01+505.00
Porsche A40
Castrol GTX High Mileage 5W-40
API SM/CF
ACEA A3/B3, A3/B4
MB-Freigabe 229.3
VW 502 00/ 505 00
BMW Longlife-01
Mobil Super 3000 X1 5W-40 Motoröl
obil Super 3000 X1 5W-40 erfüllt oder übertrifft die Anforderungen von:
API SM
ACEA A3/B3, A3/B4
Qualitätsniveau API CF
Mobil Super 3000 X1 5W-40 hat von den folgenden Herstellern Zulassungen:
Opel GM-LL-B-025
Mercedes Benz MB Freigabe 229.3
Porsche Porsche A 40
BMW BMW Longlife 01
Renault Renault RN0710
Shell Helix Ultra 5W-40
pezifikationen:
API SN / CF
CEA A3 / B3 / B4
Freigaben:
BMW BMW LongLife 01
Porsche Porsche A40
Ferrari Ferrari
Liqui Moly Synthoil High Tech 5W-40
ACEA A3 · ACEA B4
API CF · API SM
LIQUI MOLY empfiehlt dieses Produkt zusätzlich für Fahrzeuge, für die folgende Spezifikationen gefordert werden:
BMW Longlife-98
MB 229.3
Porsche A40
VW 502 00/505 00
Liqui Moly Leichtlauf High Tech 5W-40
Freigaben:
ACEA A3-08/B4-08 ; API SM/CF ; BMW Longlife-01 ; MB-Freigabe 229.5 ; Porsche A40 ; Renault RN 0700 ; Renault RN 0710 ; VW 502.00 / 505.00
Aral HighTronic 5W-40
ACEA C3
API SN/CF
BMW Longlife-04
Opel dexos2®*
Mercedes Benz MB-Freigabe 226.5/ 229.31/ 229.51
Porsche A40
Volkswagen VW 502 00/ 505 00/ 505 01
0w30
Shell 0W30 AV-L
ACEA C3
API SN
BMW Longlife-04
dexos2®*
VW 502 00 / 505 00
Mobil 1 ESP 0W-30
ACEA C2, C3
BMW Longlife-04
MB-Approval 229.31
MB-Approval 229.51
MB-Approval 229.52
ACEA C2/C3
API SN
Porsche C30
ACEA A3 / B4
API SL / CF
0w40
Nissan GT-R
BMW LONGLIFE OIL 01
PORSCHE A40
AVTOVAZ LADA cars
API CF
VW 503 01
SAAB
API SN/CF
ACEA A3/B3, A3/B4
VW 502.00/505.00
Porsche A40
5w30
ACEA C3
Porsche C30
BMW Longlife 04
Porsche C30
Chrysler MS-11106
B71 2297
AVTOVAZ LADA cars
ACEA C2, C3
JASO DL-1
API CF
Freigaben:
ACEA C3
Porsche C30
5w40
Spezifikationen:
ACEA C3
API SN/CF
Freigaben:
BMW BMW Longlife-04
Renault RN0700/0710
ACEA: A3/B4
API: SM/CF
Porsche A40
API SM/CF
ACEA A3/B3, A3/B4
MB-Freigabe 229.3
VW 502 00/ 505 00
BMW Longlife-01
API SM
ACEA A3/B3, A3/B4
Opel GM-LL-B-025
BMW BMW Longlife 01
pezifikationen:
API SN / CF
CEA A3 / B3 / B4
Freigaben:
BMW BMW LongLife 01
Porsche Porsche A40
Ferrari Ferrari
ACEA A3 · ACEA B4
API CF · API SM
BMW Longlife-98
MB 229.3
Porsche A40
VW 502 00/505 00
Freigaben:
ACEA C3
API SN/CF
BMW Longlife-04
Opel dexos2®*
Porsche A40
