Oil For Old Briggs+Stratton 5 H.P. Generator
New Jersey
I usually use Pennzoil SAE 30 conventional in all my small engines what is everyones opinion... I have my 5 H.P. generator and am putting in Pennzoil Conventional strait 30 tomorrow unless someone has a better idea..
Straight 30 wt. dino may make it a little hard to start in cold temps. of winter. May want to consider a 5w30 synthetic for that reason.
I've had 5w30 and 10w30, both conventional and synthetic and 15w40 in my little Coleman Powermate 1850. It must be about a 5hp Briggs flat-head on it (buried under the covers). No noticeable difference in starting between the oils given the times I've needed to start it.
It's a nice running, fuel sipping little bugger. Vibrates itself to pieces though.
Joel
Be carefull on gen. It can simply evaporate the oil due to high governor loading. On a tractor for example, the gov opens up when you turn the mower on and when you hit high grass, the rest of the time it is at 1/4-1/2 position.
On a gen, once the governor opens, it must stay there to maintain 60Hz. This will cause the engine to use oil.
5w30 / 10w30 is not a good choice. A robust 15w40, 5w-40 syn diesel oil would be better. Or if you must a 10w30 diesel oil like rotella.
a generator is going to fluxuate as well, ie running a refigerator, the butterfly/govenor is going to open up when it kicks on (much like turning on a mower deck mowing) and when it kicks off, the load will be much less. Also, assuming this is a lose built briggs L head, I cant see how using synthetic of any weight would be a good idea? Assuming this question is about a generator being used today in the USA (not even Nov yet), the best bet would be sae 30, imho
I have been very impressed with the way my generator runs on G-Oil 5w30 synthetic. ChinaMart has it.
But you will be using other things, so total load will probably be more than a mower for example. At least mine is.
Good point, I wasnt considering much other than a fridge, as I havent been w/o power for much more than 1 day in a long time. Back to oil, if the OP decides to use syn (I certainly wouldnt) in an older briggs be sure you check it, and check it often regardless of weight.
