Amsoil small engine, or Max Duty oil for propane generator?
Arlington, Washington
I have been using Amsoil Small Engine Oil in my mowers/small engines for eons. I have the Amsoil engine oil 10w-30 in my propane generator engine as we speak. I was thinking of using the Amsoil Max Duty diesel/gas 10w-30 in the OPE stuff, even the propane generator. I have some extra to use up.
Propane engine oil is very hard to obtain. Would the Amsoil Max duty be any worse to use than the Amsoil small engine oil in a propane generator. What thoughts might you guys have?
Here's a thread that ends with a post by @bpracer with an email from Amsoil stating:
You can skip the I think, I speculate, I don't own one, but... and go straight to the last post.
Yes, the Small Engine oil 5w30 is the correct oil for that application.
Thank you,
AMSOIL Technical Services
Tech Line: 715-399-8324
Email: [email protected]
https://bobistheoilguy.com/forums/threads/low-mid-saps-oil-for-propane-generator.378643/
Interesting...... I never saw anything about the propane use with the Small Engine Oil tech document. Maybe I'll use the Max duty on the non propane stuff. Thanks
