D_Ville_TX,
I will share my opinion, for whatever it is worth. At work, I maintain a 17ky Kohler generator with a 4 cyl. Ford engine running on natural gas.
I inquired to both Kohler and Ford about the need for special oil and they said I would be fine with "regular" oil as long as I kep't to the recommended OCI. I.E., avoid depleting the additive levels via extended oil changes.
Google "oils for natural gas engines" to find lots of informative links. The problems seem to revolve around high ash levels and oxidation/nitration problems that can occur with natural gas.
The new generation HDEO CJ oils are "reduced" ash at about 1% +/-, while the special nat. gas HDEO oils are around 0.5%+/- ash. The NG oils have other additives to compensate for the very low ash (added valve recession possibility) as well as other problems.
All the links seem to deal with VERY heavy industrial engines,..... heavy equipment and/or factory type installations. The only low ash natural gas oils available seem to be 30, 40 and 15w40 grades (although I thought I saw a John Deere announcement of low ash 10W30 JD oil???).
In my search, I never found anyone to recommend that I use a special natural gas oil for my application.
Someone with more knowledge please chime in! Why would special natural gas oil be less critical in smaller engines?
