Donald
Originally Posted By: UltrafanUK
Ahh! Don't think that extending an OCI or ignoring an OLM warning is OK just because you are using a better oil. If your vehicle is out of warranty the only safe way to extend the OCI is with a used oil analysis series.
Contamination of the oil effects a full synthetic just as badly as a conventional base oil and they only last longer if you have an engine that causes high temp shearing. Most of those engines have a hot running turbo or have high reline RPM limits.
PS: There are quite a number of 0w30 oils that are OK in a diesel car, including Edge and Ultra.
I have done a used oil analysis on the Motorcraft 10W30 and the oil was good when dumped. So the T6 synthetic should provide even better oil performance.
