The M273 engine isn't that common, they didn't sell that many of them although it was basically just the V8 version of the V6 engine which was much more common. With that said, this is not a common problem, haven't really heard much mention of this in the E class forums. It's probably why you see more mention of it in the C class forums, they sold a lot more of those and those reference the M272 engine.60.000 miles and it knocks. Yep, German cars are great. I would add something like Cerrocoat or some other slippery stuff to help keep it going.
Good luck.
What in the VOA exactly do you see that makes it not "the best thing to do"?I didn’t know it was a common issue. My car, 08 E350 with a M272 has the same issue, though I am at a tad over 180k miles. I’ve had it for about a year now and thought that it was lifter noise or that it was just me hearing things. The owner before me used Motul 15W-50 for at least 3 oil changes as recommended by the shop he serviced it at and the first thing I did was to put Mobil 0W-40 in it. I change it every 7500 miles because the OCI in the car is set for 15000 for whatever reason. Since I though it was lifter noise I purchased Liqui Moly Leichtlauf High Tech 5W-40 to give it a try but looking at VOAs it doesn’t seem like the best thing to do. Any suggestions?
Ahh I see. You question the ability of Liqui Moly to properly formulate an oil to achieve Mercedes-Benz 229.5 approval.The lack of molybdenum in it. I will be testing it out anyways though since I have already purchased it. Maybe I’ll be proven wrong. I am in no regard an expert in the field.
Yes, its all fun and games until somebody hits your beloved car, I still miss my 2.5 SEL Jetta!Price always go down over time but I suppose it will reach a point where they will start to go up again. Plus all it takes is one idiot on the road to smash your ride. Probably premature to buy an engine although I suppose you could always turn it into a table stand.
Could it be a piece of sludge in one of the oil holes in one of the bearings?? The car did sit a lot. Also MB has had problems over the years with engine parts not being properly hardened by their suppliers. I agree with the idea of taking it out on the interstate for a long blast.Wow, that other thread is wild!
Multiple different issues, some folks had cold start knock, a couple of them had the same as you (warm start knock) and two people had their main bearings (and who knows what else) replaced but their noise was getting worse. One guy had his timing chain guides replaced, but his noise seemed to last longer (5-10 seconds) and it seems most people just live with it if it doesn't get worse. Another guy had his oil pump replaced due to low oil pressure (which didn't help, this DOES point to worn bearings) and the one guy that had his bearings replaced had another Merc that made the same noise but it self-rectifiedSomebody asked him to provide a list of what was actually replaced, but he never got back on that.
So, it seems that going through the process can indeed result in the noise being eliminated. Depending on the cost, if it isn't getting worse, it might make sense to just keep an ear on it. On the other hand, if it is driving you nuts, it sounds like going through the process of getting the mains replaced has yielded some success for those who have followed-through with having it performed so it may make sense to do so. No wizard in a can is going to help (and that was covered in the thread, heavier oil did NOT improve things) so either live with it for now or get the work done.
The Mobil 1 5w40M was/is made specifically for MB. It wouldn't hurt to give it a try.That's what I was planning on doing. Just wasn't sure what to try after the Liqui Moly Leichtlauf High Tech 5W-40. I was thinking either 5W-40 Formula M or the Castrol 0W-40 that can be obtained from Walmart.
I wouldn't go too crazy trying to find the magic oil that will fix it. At least use 229.5 oils, there's only one Redline 5w40 that meets 229.5. Your Redline 5w30 does not. I would just stick to either Castrol 0w40 or Mobil 1 0w40. You can try Mobil 1 Formula M 5w40, it's what the Mercedes dealers carry and use in the AMG engines too. I'm not sure the extra cost over regular Mobil 1 0w40 is worth it though. And 2k is way too often, many people get 100k+ or more just doing regular 10k oil changes. MB used to do 13k oil changes but people couldn't stand it that long so they went back to 10k oil changes.I've tried a number of remedies, but nothing helped at all. I've used Sea Foam Motor Tune-UP in the crankcase, flushed the crankcase several times with the service at Valvoline, and used Marvel Mystery Oil in the crankcase for 3k miles, all while the car was in the 30'sk miles. I tried a number of different oil filters. I always used Mobil 1 European 0w-40, changing it ever 2k miles, and added Liqui Moly Mo2 for the last 5k miles. I just switched to Redline Premium 5w30, with Rislone Nano Prime additive. I replaced spark plugs. I used all sorts of Techron, acetone, Marvel Mystery Oil, Liqui Moly Valve Clean in the gas. As I said, nothing made any difference, although all the treatments greatly improved idle, pick-up acceleration, gas mileage, transmission shift points, even cured oil leaking from the rear camshaft seals.
Wow, way too much work on the car. I just use Mobil 1 or Castrol 0w40. Whatever is on sale. Had some Pennzoil 5w40 a while back and even Castrol 0w30 at one point when it was $2 a quart. Have over 120k on one M272 engine and 130k on the other. I tend to change it between 8-10k. The black color is due to oil doing it's job and keeping the engine clean. The cars hold 7.5-8.5 quarts of oil so it's not like other cars which only hold 4-6 quarts of oil. I don't use any gas additives either but you could just stick to top tier fuel which has Techron in it. Costco is also top tier. You can also try the transmission ECU reset, that actually wakes the engine up more than anything you're doing. Tends to get sluggish after a while. Have you changed the oil separator? I'd also keep an eye on the oil cooler gaskets and the 3 rear oil plugs along with the oil breather cover.Thanks for the tips. I might try Mobil 1 Formula M 5w40 next time. I used Red Line High Performance 5w30 based on the recommendation of the Red Line site. Red Line considers it better than the Professional Series that MB approves. I've decided to use the Rislone additive because I've read that the combination of tungsten and molydenum are the very best for ant-wear and anti-friction.
I understand that I'm changing the motor oil too often. I change it every 2k based on how black the oil becomes. The motor seems to run at a very low rpm and, given the occasional short, slow trips my mother takes to the supermarket, there seems to be a lot of carbon buildup throughout the engine (think cold, smoky combustion plus blow-by). It's why I had to use all the flushes 20-30k miles ago. I've read that the black color is mostly due to soot, which turns to sludge after enough heat cycles. Now, the car never loses pick-up with the frequent oil changes together with Marvel Mystery Oil and Star Tron Enzyme Fuel Treatment Concentrate in the gas tank. Also, I change the air filters every 2k miles, because they appear to clog that rapidly (just hold them up to the sunlight and see for yourself).
I welcome all of your analyses. I've come up with this routine after a lot of experimentation. It's the only way I seem to be able to keep the engine acceleration fresh without all the crankcase flushes, additional fuel additives, and harsh "Italian tune-up" blasts at wide open throttle.
I just spoke to an engineer at Red Line (Dave, (707) 751-2914). He said that the Red Line Performance Series does, in fact, meet MB 229.5 standards, as the Red Line website states (see OEM Compatibility tab). Red Line does not submit the Performance Series to MB (only its Pro Series), so that's why it doesn't appear on the official MB 229.5 list. Submitting the oil to MB would drive up the cost prohibitively. Dave also said the Performance Series contains only Class IV & V base oils (not Class III like many other major "synthetic" manufacturers). In Europe, anything containing Class III can't be labeled "synthetic." Those other oils for half price never mention how much Class III they contain! Also, the NOAK number published by Red Line is indeed ASTM D5800 and it blows away Mobil 1, Pennzsoil and the others.I wouldn't go too crazy trying to find the magic oil that will fix it. At least use 229.5 oils, there's only one Redline 5w40 that meets 229.5. Your Redline 5w30 does not. I would just stick to either Castrol 0w40 or Mobil 1 0w40. You can try Mobil 1 Formula M 5w40, it's what the Mercedes dealers carry and use in the AMG engines too. I'm not sure the extra cost over regular Mobil 1 0w40 is worth it though. And 2k is way too often, many people get 100k+ or more just doing regular 10k oil changes. MB used to do 13k oil changes but people couldn't stand it that long so they went back to 10k oil changes.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
