Originally Posted By: juggernaut
FWIW, my brother also tried Mobil 1 0W/40 in his twin turbo LS2 and in this motor the oil pressure gauge showed oil pressure dropped to zero at hot idle with an oil cooler fitted!!! He has used Castrol Edge 10w/60 ever since and has been fine for the last 11 years with the twin turbos and this state of tune.
Interesting. I didn't know the cold weather rating worked that way. It sounds more like a hot viscosity problem to me.
The problem is, a 40 weight oil is having to flow to meet the 0W rating. This is also the point I was making about Mobil 1 5W/50 in my car. Such oil is all well and good in your daily driver but compromised in modified motors making double to triple the stock hp that are driven hard. I think GM normally recommends 5W/30 in their V8's but a 15w/50 if they are tracked.
IMO the larger the spread between the two specs the more compromised the oil will be when pushed.
Translation: This oil is broken?
