If I read his post correctly, Doug is talking about gallery loss after 300 hours of operation... e.g. a filter that is nearing or at it contaminant capacity. That's ~12,000-18,000 miles in service.
DP or "flow" is a function as much of oil viscosity as it is the filter efficiency. If you need more cold flow, there are two ways to achieve it; better cold flow characteristics from the oil (lower "W" numbers, higher VI) or a less restrictive (less efficient) filter. In light of the oils we have today, going the second route seems counter productive to me.
One of the more interesting things said by Doug was : "In the tests referred to the differential by-pass operating range was 15-22psi. The cellulose filters typically took an oil temp of around 70F to avoid bypass, with synthetic media this was 40F." This is illustrative of the superior flow characteristics of synthetic media in general. It would be interesting to know some more details in that case... I presume the oil was the same viscosity but were the filters of the same efficiency?
Generally speaking, the superior flow characteristics of synthetic media allows for higher efficiency with no loss of flow (vs cellulose) plus higher capacity and longer life. In other words, you could replace a 35 um absolute cellulose FF filter with a 20 um syn. filter and have the same or better oil flow along with as much as 40-50% more capacity in the same physical size filter. I was speaking generally there, the exact details could vary alot.
As to not trusting public filter efficiency ratings, beyond mistakes If we cannot trust what we are told about filter efficiency (generally speaking), especially now that the manufacturers are presenting the test data according to ISO test standards, how can we trust anything we are told by any parts or lubricant manufacturer? Am misinterpreting what Doug is said? If so, perhaps he could clarify his remarks.
