isnt there a oil filter spec sheet somewhere on here? the conundrum i have is there are two honda's, one specs a wix 51064, the other specs a wix 51357. i have a shelf full of the 51064, but none of the 51357. thread & gasket diameter are the same, and i have already put it on. my question is what are the internal differences between the two, the 51064 is much larger than the other, which is good, but unless there are major differences internally between the two i am going to continue using the larger.
thanks
thanks
