...effect oil pump operation?
I have a Toyota Starlet and i have just installed this oil filter relocation kit;
http://www.autoaccessorystore.com/products/2164_b.jpg
The reason i installed was to make oil filter change's easier as it was in a very hard to access location + i had gauges to install which i can now hook the sensor's onto the relocation kit.
I have the oil filter positioned about a foot (30cm) above where it originally used to be housed. I have used one meter length's of oil hose so the oil pump will have to move the oil one meter to get to the oil filter then return back another meter. Will there be any adverse effects to the oil pressure?
I'm jus' abit worried about cold starts because the car has a turbocharger that receives it's supply of oil after the oil has been filtered?
I've jus' got a K&N filter which activates an anti drain back valve upon shutdown of the engine and hope this may help so i don't run dry on startup and hope it does it's job.
All help much appreciated.
Hits.
Hits.
