Ascent Filtration Testing
- Joined
- Nov 29, 2020
- Messages
- 184
Sorry Zee, having issues with the typing format of this blog.
Thanks for the correction EvoMan, lol I always mix these 2 weekends up. We all certainly hard and deserve an extra day off to be with the fam. Have a great weekend!Memorial Day was in May. This is Labor Day weekend.
I gleaned what you said, which was:Sorry Zee, having issues with the typing format of this blog.
Yes, as long as prior to starting the test we know you want that.I gleaned what you said, which was:
"It would include the Differential Pressure at a constant flowrate of 25LPM at time 0 minutes-15min, 1 reading per minute-16 total DP readings. The capacity is not included. The remaining capacity can be tested for on a used filter, but is not in the scope of this particular test."
Any way at the end of the 15 minute test you could easily change just the flow rate to a couple different settings (+/-) and get at least 3 delta-p vs flow rate data points?
Yes because I’d love to see which filter is better the new fram ultra or AmsoilOK, @wwillson do you want to set this up and we can all donate?
I assume a poll to determine the filters and then we can all donate.We haven't seen Andrew for a while... hope he's OK.
As for a group donation - how are we going to decide what filters.... it's an intriguing concept i might be in for, but what filters to test i see being problematic...
His last post was in this thread, I hope he's OK as well.We haven't seen Andrew for a while... hope he's OK.
Well, I would like to see the Amsoil EAO filter tested to compare it to the stellar results from the Fram Ultra. But maybe the "new" Fram Ultra should be tested to see if it is performing as well as (or better than) it's prior incarnation.I assume a poll to determine the filters and then we can all donate.
Yes, I would like to see both the EaO and the new FRAM XG (Ultra). Would also be interesting to see a Fleetguard Stratapore and Donaldson Synteq filter, but I'm probably asking too much with that, lol.Well, I would like to see the Amsoil EAO filter tested to compare it to the stellar results from the Fram Ultra. But maybe the "new" Fram Ultra should be tested to see if it is performing as well as (or better than) it's prior incarnation.
