Quick lube places yes. Most people here know to look at the removed filter.
Sometimes the gaskets sticks - curious if you'd reuse that? some guys would other wouldn't.
I'm not sure where you would even find a replacement gasket? If it sticks, why do you think it can't be removed and reused? It's not a head gasket, just a simple piece of synthetic rubber material. Unless it's hard and brittle, it should seal just fine.Sometimes the gaskets sticks - curious if you'd reuse that? some guys would other wouldn't.
What he ^ said.Want easy change , get an newer SUBARU with oil filter at top of the engine and use the extractor .
But then you would have to drive a Subaru.![]()
What he ^ said.
Except who wants to buy and drive a Subaru? So get you a VW, Audi, Porsche, BMW, Mercedes, or Jaaaag
these are the people you have to share the planet’s resources with every day
I use the Mityvac manual pumper type, I think it holds around 6 gallons and was about $100 on Amazon. I'm very pleased with it.
I think EVERY modern vehicle should have top side dipsticks that allow extractors to work. The costs of maintenance would plummet.
If you're referring to Mityvac 7201, it holds about 8 quarts, works great.
Agreed. Also it helps to have top side cartridge filter makes oil & filter change a breeze.
My new Jaguar F Type is designed for top extraction and the cannister filter is also on top. While you can still pull the drain plug and drain from the bottom, that requires removing a bunch of underbody aerodynamic panels.
I'll be buying a Mityvac 7201 soon plus the special filter wrench and doing my own changes in between the free changes that are covered for the first five years. The factory recommended OCI is 16,000 miles or one year but I want to change out the factory fill at around 2500 miles. It will be nice not to have to pull up on ramps and crawl around under the car for a change. Also I understand that it is very easy to reverse the flow from the Mityvac once it is full and pump the oil into containers for recycling.
No matter how careful I have always been and have always worked over a steel drip pan, there is always some mess to clean up, wipe down funnels and all that related stuff that goes along with traditional methods. I think the extraction method is going to be much less of a chore and more like a surgical technique.
