Oil drain plug problem
Would rubber o-rings you can buy in a hardware store for plumbing work? would the material they are made of stand up ok between OCI's? I can get them dirt cheap.
Originally Posted By: Oldmoparguy1
Is this the 4 cyl. engine? I've never seen that type of drain plug on any of my mopars. All of mine have had a flat nylon gasket. Some time back I bought a package of them from rockauto. One time, in a emergency, I used a 14mm sparkplug gasket. It worked well enought until the next oil change.
Wayne
the type of plug/gasket the OP describes is exactly what my neon had. (2L 4cyl)
I Replaced the whole thing on My second or third Oil change (4th since i bought it)as the Techs where i had previously had it changed, put it on Gorilla tight, and i had rounded off the corners before I got it broke loose.
(And I had used the wrong socket, it took a 13mm, I used the roughly equivalent SAE size...)
here's the one i bought:
http://smile.amazon.com/gp/product/B000CGMPX2/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1
I solve the problem by finding the thread pitch of the drain plug, the find a plug that has a copper gasket that goes between the head of the bolt and the oil pan. The head of the replacement bolt sometimes had a different diameter than OEM, but it always sealed correctly.
This works for most drain plugs that GM and Chrysler use.
No, don't use a regular o-ring for this application. Tightening the bolt will just flatten the o-ring and force it out from under the bolt head.
O-rings for engine oil are a specific material, the ones from a hardware store are probably not engine oil resistant anyway.
Originally Posted By: 01_celica_gt
I mean my wife hand tighten her last oil change...no leaks...
A wife that changes her own oil? She sounds like a keeper.
My high school girlfriend was like that. Her dad owned a race car frame shop, so she grew up working on stock cars. Boy, high school was fun.....
I lost my original drain plug on my GC when I installed a Fumoto valve. I later removed the Fumoto. Subsequent drain plugs have not held up. Now that I am back to doing my own oil changes, I re-installed the Fumoto valve.
How about a water hose washer? Those should work, I would suspect and are easy to come by.
