Oil Choice For New Honda 3.5L
As for Mobil making Toyota oil... AFAIK Genuine Toyota motor oil and Mobil 1 use the same base oils. You might be correct in saying the additive package is somewhat diiferent. For the sake of discussion, let's assume the additive package is different. So what? Different does not mean it's better or worse. It means a different approach was used. Both approaches can be good. Do you think Toyota knows more about making oil than Mobil does? Mobil made the Toyota oil with the additives that Toyota requested. If Toyota and Mobil 1 oils have some differences in additives, I'm equally confident in both brands of oil. Also, having the same or very similar base oils would make them similar. I have equal confidence in both, but M1 costs less at Walmart.
This is a whole lot of word salad to just say, "Mobil 1 and TGMO are different oils. They are both acceptable, regardless".
OEM Genuine Honda motor oil is made by Idemitsu. It's the same motor oil, but it's cheaper when purchased with Idemitsu name on the bottle. Rockauto, NAPA and some other autostores sell Idemitsu oils. Oreilly does not.
OEM Genuine Toyota motor oil is made by Mobil (according to Lake Speed Jr). At least for Toyota oil sold in USA. It might differ elsewhere in the world. As far as I know, all Toyota oil is synthetic oil. It's Mobil 1 oil in a Toyota bottle. You can buy the same oil for less money by buying Mobil 1 from Walmart.
I'm not suggesting anyone needs to limit themselves to those car brand OEM motor oils, but if you want to stay with them, then I suggest buying them from lower cost sources as I described.
Has this changed in the last 6-12 months? Because this is Hondas ultimate full synthetic oil:
And this is P66 oil:
Notice any differences or similarities?
Oh, also this too:
Product Identifier: Other means of identification: Honda Genuine Ultimate Full Synthetic Motor Oil
Honda Genuine Ultimate Full Synthetic Motor Oil, SAE 0W-20
Honda Genuine Ultimate Full Synthetic Motor Oil, SAE 5W-20
Honda Genuine Ultimate Full Synthetic Motor Oil, SAE 5w30
Honda Genuine Ultimate Full Synthetic Motor Oil, SAE 10w30
SDS Number: 817725
Intended Use: Automotive Engine Oil
Uses Advised Against: All others
Emergency Health and Safety
CHEMTREC 800-424-9300 (24 Hours)
Number:
CANUTEC 613-996-6666
CHEMTREC Mexico 01-800-681-9531
Manufacturer:
Phillips 66 Lubricants
P.O. Box 4428
Houston, TX
Idemitsu made Honda oil in prior years. Then they went to P66.
Honda and P66 have a huge partnership now, including their racing section: http://phillips66lubricants.com/news/honda-racing-partnership/
https://www.machinerylubrication.com/Read/30480/phillips-66-honda
It seems unlikely that Honda would have huge partnerships with P66 and switch back to Idemitsu so based upon this info, I'd say the Idemitsu is old/outdated or Honda is making multiple partnerships that aren't public to deliver their oil to customers, maybe depending on geographic locations.
With the cold and short trips, I would recommend doing OCI at 5k not MM. Do one or two used oil analysis after your normal intervals, use Oil Analyzers or others that do GC (not Blackstone) and make sure to request the GC for fuel dilution. I didn't request on one from Oil Analyzers so they didn't do it. Base your OCI's from there. The Lake Speed thing is good but that will give you results possibly 4 years from now depending on use.
I drove my wife's '19 Pilot a bit longer to get it hotter but no long trip. The oil test IMO was what the motor sees everyday, no special accommodations. Lots of short trips, sits outside 24/7/365, not as cold as OP. https://bobistheoilguy.com/forums/threads/blackstone-vs-oil-analyzers-pp-euro-l-5w30-5175-miles-19-pilot-67k-miles.392379/#post-7154514
Mobil 1 ESP has more certifications and an excellent choice. For me the Valvoline Restore and Protect is in my Pilot with a big reason that the VCM is active and knowing history of ring issues caused by VCM in older Honda's. I'd rather prevent that issue and changing earlier is helpful IMO. used oil analysis is great reference and I do them. The cost of used oil analysis = DIY cost of oil change for me or basically like changing every 2500 miles with no used oil analysis for same cost. One of my vehicles is on 3k/6 month from tested fuel dilution, one is now on 4k changes that had motor replaced due to oil burning, stuck rings, scored cylinders at ~7500mile maintenance minder changes at dealer prior.
The Valvoline Restore and Protect 0W-20 is easy to get, will keep it clean, satisfy warranty documents, not expensive for early changes. If your used oil analysis shows high wear metals due to short trips and fuel dilution, bump to higher grade like 5w30 Valvoline Restore and Protect. Keep all the information and if any ever issues you can show why you went higher viscosity.
Next oil change in the Pilot I'll probably do a used oil analysis just to check on the Valvoline Restore and Protect 5w30 as this is my second OCI with it. Might be a bit off as it will be probably about 5500 miles with a 4-5 day, 1000 mile round trip to Virginia upcoming in 2 weeks.
What you said seems plausible in regard to Honda Genuine motor oil. I wonder if Idemitu is still making Genuine Honda Power Steering Fluid, DW-1 ATF, gear oil, etc?
Very possible. P66 probably just gave them a nice discount for bulk supply vs Idemitsu so their partnership and cheap product = win
VCM-3 does not appear to have the same issues as VCM-1 and -2. There are some anecdotal stories on Odyssey forum about issues but not nearly as widespread as prior years. That said, mine has been muzzled since week 1 of us owning it. =o]
That seems plausible.
I bought some Idemitsu PSF 2 weeks ago. Last week I went to a health food store for vitamins. I noticed the local Honda dealership across the street. So I went to the Honda Dealership parts dept and asked if I could look at bottle of their Genuine Honda Power Steering Fluid.
I compared the bottle of Genuine Honda Power Steering Fluid to a bottle of Idemitsu PSF I had with me. Same bottle, diiferent label.
I also compared the safety data sheets for Genuine Honda Power Steering Fluid to Idemitsu PSF. They're not the same PSF. 100C cSt is 12.6 for Honda, 7.65 for Idemitsu. Both the Honda Power Steering Fluid & Idemitsu PSF have the Idemitsu name and logo in their safety data sheets.
So for PSF it's same bottle, different names on labels of bottles, different oils, but both made by Idemitsu according to their safety data sheets. Genuine Honda Power Steering Fluid has the proper viscosity for Hondas.
Similar situation with Honda DW-1 ATF and Idemitsu Type H Plus. Same base oil, same viscosity, different additives, both made by Idemitsu (unless that's changed). Regarding the difference in additives... Different doesn't mean better or worse. It just means a different approach was used. Some Honda owners report using Idemitsu Type H Plus ATF with better results than they got from Honda DW-1 ATF saying Idemitsu Type H Plus gives smoother shifts.
Regarding Genuine Honda motor oil, I don't know. It for sure was Idemitsu worldwide, but now might be Philipps 66, at least for Honda USA. I wonder if it's still Idemitsu making Genuine Honda motor oil for use in Asia and Europe?
I'm open to other options FYI
A cautionary tale:
I parked a company truck at a hotel in Hinton. AB one night a few years ago. Overnight the temperature dropped to minus 42C. The next morning the truck, a 2017 GMC with the 6L gasoline engine started, but there was no oil pressure with fast lube 5w30.
After the third time of starting it and letting it run for 15 seconds I got oil pressure.
Same ritual for a truck that was parked overnight at Hinton Pulp.
After work I went to Walmart and bought three jugs of Mobil 1 0w40, went back to the mill after eating and changed the oil on both trucks.
The cold spell lasted a week with no more zero oil pressure cold starts.
A good rule of thumb is to go one winter grade lower than you think you’ll need.
FYI, Petro-Can pcmo’s meet API SQ with pour points for life in the 51st state.
TGMO 5w30 is still conventional.
I would think if there was a problem with Honda oil, Honda dealers wouldn't be using it. Then again, their bulk tanks may be refilled regularly from "Joe's Custom Blended Motor Oil & Salvage Yard". No offense to the Joes out there.
Exactly. Honda isn't using Honda oil. They are buying the cheapest bulk oil they can find that barely passes spec.
Honda dealers are selling it, but the techs are more than likely not using it on your car when it's serviced. Who knows what their bulk stock actually is.
I don’t think many people realize that most of the world views oil as a fungible commodity. Which means they will always shop on price and choose the minimally sufficient product. Dealers are no exception. They’ll use whatever they can get cheaper through local distributors, as long as it meets the not-remotely-stringent Honda requirements.
Doesn't that describe ⅓ of BITOG members too? 😁
We've heard it many times by many members saying they buy the cheapest oil available that meets certification requirements of the vehicle. You'll also hear them say that certification the only thing that matters. They really mean certification and price matter. I see their logic, but I have slightly higher standards.
However, if I was following that logic, I'd at least want to stay with the same brand & model of low cost oil to keep the additives consistent to avoid potential additive conflicts.
I do somewhat practice that logic myself. First I investigate which cheap oils I think are the best cheap oils. Good cheap oil is my goal. I compare datasheet specs (especially cSt) and compare regular prices (not sale prices) because I want a consistent low price. I also look for easy availability. Then I try to stay with my oil of choice.
That's what I try to do, but then persuasive people at BITOG tempt me to change to a different oil that's better quality for equal cost, or equal quality for lower cost. Then I'm too weak to resist the temptation to switch to a different oil. 🤷
There used to a time when you were reasonably assured that dealerships would be using their manufacturers branded oil mostly - like TGMO at Toyota dealership, BMW Twin-power at BMW dealrships, but nowadays it's likely that it is mostly bulk oil (cheaper than the rest) that meets spec - though I am not sure how anyone can say for sure which oil comfortably passes specs vs one that barely passes spec.
I am sure that the Honda branded oil at their dealerships are made to their specifications. I am sure that Honda is not overpaying for the oil, but to say it "barely passes spec" ---> do you have any proof or inside knowledge on that?
Dealerships don't have to use the OEM oil. His point is that dealer service department bulk tanks are often filled with the cheapest "meets the spec" oil that they can locally source.
  • Like
Reactions: GW.
They don't use OEM oil, just like you don't get TGMO at Toyota dealers. Like others have mentioned, you get cheap bulk oil. This is corroborated by many people who work at dealers in the service department. They are there to see how the bulk tanks get filled. For Toyota anyway, you can pay more and specifically request TGMO, but again, it's a special request and more expensive. Doing an HPL change yourself would be far cheaper.
