Originally Posted By: Kyonic
I have narrowed it down to Mobil 1 5w30 and Pennzoil Platinum 5w30. Not sure which just want to keep the warranty going.
In that case the only choice is the Pennzoil Platinum 5w30, as it meets the requirements for hyundais warranty. I think the cert was ACEA A5 that Mobil 1 didnt meet (maybe the Extended performance did, but i dont think so).
Factory fill is shell helix 5w30 semi syn.
As a side note, I kind of mentioned it above but... if you are changing the oil yourself through typical means such as pulling the car on ramps, be sure to use a fluid extractor to get the most out possible. the drain plug is on the front of the pan, so the ramps tilt the pan back. I get about 3/4s of a quart out after draining from the pan.
