Oil change without bypass oil filter change
Near the beach in Delaware
So it will shortly be time to change the oil in my truck. Or at least pull UOA. When I do indeed change the oil what about the roughly 1 qt that is in the bypass filter I am not planning on changing? I assume ifs not good practice to unscrew the filter and dump oil and screw back on the filter?
It would be 1 qt of old out of 14 or 15 qts. So percentage of old is not high.
A used oil analysis will tell, but generally, leaving the bypass alone, changing the full flow, and topping off will extend the OCI by 2x.
Pull a sample and see where you are at.
Originally Posted By: Donald
Originally Posted By: UG_Passat
You are supposed to change the "full flow" filter in between bypass filter changes.
Yes, but when to change the oil?
That's why you do used oil analysis.
