Guys with VW TDI's and BMW's love these. My BMW comes with a cannister filter right at the front and top of the engine. 36 MM 6point socket removes the cover, and you just pull the filter cartridge out. I even opened it up midway through a ARX clean cycle to make sure it was doing OK.
I change the filter while the topsider is sucking the oil out. Alogether it's truly a 5 minute job that can be done in your business suit without getting any oil on yourself.
A few guys on a bmw e46 discussion site were disputing whether "topsiders" are a good idea. The critics say that you don't get as much oil out of the sump with a topsider. He was challenged on that point by a topsider owner, and he drained his pan the conventional way and replaced the drain plug. The guy with the topsider came along and pulled out another 7oz of oil with his topsider from a "drained" engine.
Additionally, since this method is so efficient, many BMW dealers change to oil this way. The car doesn't have to even be brought into the shop.
In case you haven't guessed, I'm a big fan. If you own a bmw or a TDI VW with a cannister filter, it makes oil changes almost as easy as filling your wiper fluid.
The trick is to make sure to get one that can hold all of the oil in your sump. This was a little more difficult for me since my sump holds 7 quarts.
