Yes, it is out of the question. I would not spend $40 x 5 times = $200 to confirm what I believe to be true. However, I would spend $100 to have Blackstone add a particle count to used oil analysis (hopefully at some reduced rate) already being done for engines / filters meeting particular criteria (well running engine, 5000 mile OCI, no oil additives, no fuel additives, stuff liike that) and share that info with all the BITOG members.quote:
Originally posted by 427Z06:
So getting you to change filters 5 times and doing a particle count is out of the question?![]()
I suggsted this to Tony a while back and I have not heard from him (guess he did not like the idea), I actually suggested you set up the criteria for test selection (engineering background better than us generalists).
