I off-road on very dusty roads some in my ‘13 Chevy Silverado 4x4 (stock) and would like to know what the recommended oil change frequency is. Miles on engine = 70K.
keep a good air filter on the vehicle and inspect intake tract for dust. if it’s clean there is no real need for an early change. on LS motors i run OTS synthetic oil (ep versions) to 6k.I off-road on very dusty roads some in my ‘13 Chevy Silverado 4x4 (stock) and would like to know what the recommended oil change frequency is. Miles on engine = 70K.
I used to wheel Jeeps a lot. Sometimes in dusty environments. Specifically Mt St Helens powery volcanish ash. It was as fine as flour.I off-road on very dusty roads some in my ‘13 Chevy Silverado 4x4 (stock) and would like to know what the recommended oil change frequency is. Miles on engine = 70K.
Yes. Good point. My advice for OCI was for a guy who isn't doing UOAs. My other advice is for every wheeler regardless of UOA or OCI.This is a perfect example of how a few UOAs can help you fine tune your proper OCI. It will take the guesswork out of how much of that dust is making its way into your oil.
I suggest going to a slightly thicker and heavier duty oil, especially if you're wheeling in hot weather, and especially with a high mileage vehicle. My favorite oils for that are:OP here - thanks for all the really helpful & useful info - keep it coming!
P.S. - My advice to (if dirty enough to need it) vacuum the dirty side of air filter is what I do (because I don't have an air compressor).Once a month or after a dozen dusty wheeling adventures... Wipe dust off top and sides of air filter box. Remove air filter and look at it.
If it's white it's still clean. If it's light brown/tan, light grey (or darker) it's dirty. Vaccuum it as clean as you can. Take care to only vaccuum the dirty side so you pull dirt out. Do not vaccuum the clean side at all (because that would just suck dirt deeper into pores.
Hold filter up to the sun (cleanest side toward you). If you see light through the filter it's still good and should be reused. If you can't see light through the filter it needs to be replaced.
I also suggest changing oil and oil filter every 5K at longest or 3K at soonest if you're not doing UOAs. If you are doing UOAs then I suggest letting the UOA guide you for OCI.
I like to change oil and filter before and after. I'll admit, I grew up working on a 36,000 acre ranch and it was dust as hell. Way worse than any off roading I've seen. We'd hit our filters with an air compressor and it made your jaw drop. Never had an engine issue. My reasoning is because A) for some weird reason I enjoy knowing the engine is clean prior, and B) I like to send a used oil analysis in. However, when I didn't let it get to me (broke college kid) I worked those farm fields that SHOVED dirt down the pipe and still sold my vehicles running perfect.I off-road on very dusty roads some in my ‘13 Chevy Silverado 4x4 (stock) and would like to know what the recommended oil change frequency is. Miles on engine = 70K.
