Vehicle and current oil fill: In sig.
In the next month or so I'll be getting the following work done to the Outback:
New timing belt, pulleys, tensioner, water pump, crank seal, cam seal, valve cover gaskets (leaking onto spark plug boots), valves checked/adjusted, and resealing the oil pump.
And then the engine should be good for the next 100k miles or until the body rusts out, whichever happens first.
Oil will have somewhere between 3000 and 4500 miles on it by the time I get the car in to be worked on. Should I change it out early after the work? Was planning on taking the PP to 7500 miles or so.
