Oil Burners Piston Soak SDS Comparison
I was just posting this for general discussion and which you think might be the strongest... Here are some piston soak treatments with a few that possibly have not been used and maybe somebody here has some input to not use based on the ingredents. .. Is Xylene the toughest ingredient?? It is now absent in the B12 where as it used to be one of the ingredients fwir. .. The white bottle of B12 fuel injector cleaner that everybody uses for piston soaks does not have it and this first one below is the SDS for that product.
Which one do you guys think is the strongest ?
B12
ACDelco 10-3015 ...... This is listed as what looks to be Lubrizol-Powerzol ZG6000 ... It seems the other ACDelco engine cleaner 10-3007 is no longer produced.
GOOF OFF ( A guy used this recently and had total success ) https://bobistheoilguy.com/forums/t...-stuck-rings-to-eliminate-oil-burning.395037/
BG Throttle Body and Intake Cleaner PN 406
BG Fuel Injection and Combustion Chamber Cleaner PN 201 ( This Naphtha below is what Liqui Moly uses for their Valve Clean )
BG Air Intake and Valve Cleaner PN 260
BG EPR 109
So what do you guys think is the strongest option here ?
I used synthetic pao ester hydraulic fluid to save 2 Kubotas with stuck rings by squirting 10cc or less into the cylinder and leaving it over the weekend worked.
The ultimate piston soak would probably be a mix of synthetic hydraulic fluid and some acetone.
