Oil and filter
Central Mississippi
Hey guys.
I have a 1993 and a 1988 ford f250.
The 88 is 4x4 and the 1993 is a 2 wheel drive service truck.
Both have the 7.3 naturally aspirated idi engines made my navistar international.
Both have the zf-5 5 speeds.
I usually run rotella t4 15w40 year round since I live in Mississippi and it hardly gets below freezing here.
I usually run tge motorcraft fl-1995 powerstroke filters instead of the shorter filter that originally came on the idi.
Not looking for a "what should I run?", but more of a "what are you guys running?".
I'm just curious as to what all the other fellow 6.9/7.3 idi owners run. Even if you don't have that specific engine, what are you running with these older diesel turds?
Thanks guys.
I use to have an 83 and 87 F250 with 6.9 IDI diesels. I use to run WIX 51742 and Chevron DELO 15w40
The 15W - 40 HDEOs oils from a major , are always a good choice. The wife a 7.3 Powerstroke though.
I just use whatever is cheapest.. because when a difference makes no difference, you might as well just save a few bucks.
