427Z06,
I ran two back-to-back OCI's for roughly 4500-5000 miles each with Mobil 1 5w30 in my '97 Maxima. Both runs, the VQ30 engine was loud and vibrated enough to feel in the steering wheel while in Drive. Both used oil analysis of the Mobil 1 showed elevated lead and iron. I returned to Castrol GTX 5w30, and the engine noise and smoothness returned to "normal". I have since run GC, and the engine was even quieter and smoother than on the GTX. There also was no measurable loss of mileage, which I calculate in a spreadsheet to the nearest hundredth, and have for years. This was not only my subjective observation, but also my wife's, and without prodding from me (she asked me if it seemed quieter when she didn't know I had changed the oil).
Numerous posts here and on Maxima.org mention that Nissan VQ's like thicker 30 weights. The manual specs 5w30 as preferred, and 10w30 suitable. The European manual for the same car specs everything from a 5w20 (but stipulating not recommended for sustained high speed driving), up to a 20w50 for hot areas. Interestingly, it also states 5w30 will positively improve fuel economy, but 10w30 is preferable for ambient temps above -20*C. In fact, the 5w30 is only recommended up to a temp of +15*C (+59*F). These differences in recommended oils lead me to believe that thicker oils work better in VQ's. This is verified by many other VQ owners, and by my own observations. And Mobil 1 (a thin 30 wt) returned two sub-par used oil analysis in my car and made the car much louder, even to the "untrained" ear of my wife.
On another note about Mobil 1, is my Mother-In-Law's '99 GMC 1/2 ton has literally had a diet of only Mobil 1 from "birth", changed every 3000 miles (probably a waste of oil as it could go longer, but it's her truck). She now has 60,000+ miles, and her dipstick is "permanently" varnished. It will not wipe off, and is concentrated on the end that constantly sits in the oil. I don't know what to think of that, but thought I'd mention it.
Due to my 2 bad used oil analysis on Mobil 1, and varnish on my MIL's dipstick, I personally will not use Mobil 1 in my 2 Nissans. Others may get good results from it, but I personally have better results with Castrol GTX and GC.
For the 5w20 "thin is in" crowd, why would Nissan state 5w20 is not recommended for sustained high speed driving? And keep in mind this is for a Nissan VQ30, which has been on Ward's top 10 engine list since the list's inception. It's not likely that Ford has much tighter tolerances. I personally opine that it is CAFE driven, and especially when "non-CAFE" regions recommend higher viscosities. Just some food for thought/discussion.
Dave
