I wouldn't say it sucks, just overly complex for what it is. The tabs and labels and such are NOT self explanatory. But a couple times through, not so bad.OAI is good, but the website sucks beyond imagination
Yeah it depends how you weight usability. They should get a UI/UX intern.I wouldn't say it sucks, just overly complex for what it is. The tabs and labels and such are NOT self explanatory. But a couple times through, not so bad.
Can't argue that!Yeah it depends how you weight usability. They should get a UI/UX intern.
It's usually been in about one week for me.How long does it take for OA to report? Sent a sample several weeks ago now.
I don’t use the app but it does come up on your account automatically. I’d call if it’s been this long.Does the report automatically generate in the Horizon app?
What OAI has to do with Amsoil?Oil Analyzers (Amsoil) uses Polaris Laboratories in Indianapolis IN. as their lab.
Oil Analyzers is Amsoil, however, they use Polaris Labs as their oil sampling lab. Polaris is a large corporation with labs around the world. They are hired by Amsoil/Oil Analyzers to do the fluids testing for them. I have my own account with Polaris. They send my tests results directly to my e-mail.What OAI has to do with Amsoil?
Why you're transferred to the Amsoil site when ordering sample kits?
Thanks a lot! That is new for me.Oil Analyzers is Amsoil
Anybody can send an oil sample in to oil labs; they are all over. All oil companies either have their own labs or hire it out like Amsoil. If they want to, Amsoil or any other oil company that has the million-dollar equipment, can do an in-depth analysis of a competitor's oil that may tell them some trade secrets. It would probably cost them thousands of dollars, if they have the equipment and desire. You can't tell that much from a basic oil analysis. You can't tell their "chemistry" or blend secrets from a basic $30.00 engine oil analysis. I am no expert on this stuff though, however, Bitog does have some chemist here that can give you more legitimate answers than I can.Well, isn't it conflict of interests an oil company (in this case Amsoil) to do oil analysis and people send them hundreds of thousands of oil samples of competitor oil companies like Mobil 1, Valvoline etc.? I understand the oil testing is performed by Polaris Labs, but still Amsoil has the opportunity to look at the oil results for free and even to charge people for that through OAI.
I’ve been looking at doing oil analysis on 2 different ford eco boost looking for fuel dilution & a 7.3L gasser and keep coming back to Speed, don’t know why exactly
I’ll suck the oil up the dipstick since I use a shop to change oil & this way have better control over the samples
after your first OAI you can submit everything online.My reason for using Speediagnostix probably doesn't apply to the majority of people on BITOG. I'm getting old and my handwriting is beyond atrocious. The sample submission form for OA (and BS) is a small piece of paper where you fill in the blanks and/or check boxes. Speediagnostix has an online form which identifies each sample by its Sample ID#. My ability to legibly fill out an online form is limited only by my typing skills, which aren't quite at the level of atrocious, yet.
My one-and-only experience with OAI was buying three kits through Amsoil and sending three different virgin oil samples for evaluation. I even had my wife fill out the forms so they were legible.after your first OAI you can submit everything online.
I did with my last sample.
Also my second sample kit actually came with an example page on how to fill it out.. helps tremendously.
This, most - well all people - never have a problem.after your first OAI you can submit everything online.
@rstcso , I use Polaris labs myself, I do my best at filling out their little forms, but then I get on my PC and type out the information and any other side notes I may have, for the Polaris people. That makes it unmistakably easy to read. I print it off my printer and fold it up and put it inside the sample container with the rest of their paperwork.My reason for using Speediagnostix probably doesn't apply to the majority of people on BITOG. I'm getting old and my handwriting is beyond atrocious. The sample submission form for OA (and BS) is a small piece of paper where you fill in the blanks and/or check boxes. Speediagnostix has an online form which identifies each sample by its Sample ID#. My ability to legibly fill out an online form is limited only by my typing skills, which aren't quite at the level of atrocious, yet.
Previously, I bought three kits from Amsoil to send OA virgin samples. My wife filled out the forms and I mailed each sample separately. All forms were clearly identified as virgin samples with the brands and viscosities noted. They still ended up comparing two of the samples against each other, highlighting in red some fields that were too far apart from the "previous" sample.
I just did the first oil change on the new Pilot (494 miles) and tonight filling out the online forms to submit a virgin sample of AMSOIL Signature Series 0w20 for VOA and a mid-stream catch of the OEM oil for used oil analysis. I realize there are quite a few recent VOAs for the AMSOIL Signature Series 0w20, but it's convenient having all the samples on the same results' reports. I'll change again at around 5k miles and send in another used oil analysis to see how the engine is "breaking in".
Even my servicing dealer tried to straighten it out and couldn't/didn't. It was a cluster.This, most - well all people - never have a problem.
