Oil Aint Oils
I read this a couple years back. This is probably why turbo'd cars and cars with stiff aftermarket valve springs sometimes do better with RP.
Please do a search before posting. This has been on here lots of times before.
The Timken test has little relevance to wear in an engine.
From Bobistheoilguy.com:
" I use an old snake oil additive salesman machine called a Timken machine. This machine was and is used only by oil additive companies only. I have not seen any oil company (except one) that will demonstrate how well their oil will hold up on this machine."
http://www.bobistheoilguy.com/oilshear.htm
This test is absolutely valid if you run your engine oil at room temperature and have needle bearings placed sideways against a larger shaft. If so I would choose an oil that performed well in this test. If I ran my engine with the ignition on and used it to generate motion and found that the oil temperature increased much above ambient then I would not be bothered if my choice of engine oil did not perform well on this test.
If I recall correctly this magazine admitted that this test was of little value and planned to find some other testing to do in the future.....
We have a winner!!!! DING DING DING
Quote:
post whatever you want, unless you live in norway, then check with bar1, as he seems to be in charge.
Hong_Kong_Phooey, what a lame statement.
I forgot to add:
