2Slow
Thread starter
Any oil will be better than what was out there in 1914.
I am trying to improve 2 specific areas:
1) Hand cranking when cold. So far the 0W-40 has done the best for this, but I am curious if other 0W oils have a lower cold viscosity. SAE30 will not be OK for easy hand cranking when cold. A lot of T's have starters, but mine doesn't, so it has to be easy to hand crank start. With the 15w40 once it did start, it would slowly creep forward from the drag on the clutches.
2) Band chatter in reverse. I think an oil with less friction modifier like a motorcycle oil may help, but I will tolerate the chatter to have a lower cold viscosity. SAE 30 might help here, but if I can't start it, I will not have band chatter.
Thanks for the ideas.
-Joe
-Joe
