I just bought a 8.1L Suburban. 2003 4x4 model with 4.10 gears, 134k miles. I will primarily use it to tow my travel trailer and will get little to no use this winter. I've tried searching for a used oil analysis anywhere on the internet and here too of course with nothing found. I use Rotella T6 in my wagon with good results and would consider that. It calls for 5w30 of course being a GM. I saw someone else a few years ago was using T6 and switched to Redline 0w30 and found the start up tick was mostly eliminated. Mine has the tick which goes away within a minute. I have no idea what oil is in it but it looks pretty fresh and I have records of regular oil changes over the last couple of years but don't know when the last change was. Should I change it now, wait till spring, any suggestions on what to use? Front crank seal was just replaced and it is not currently leaking any oil.
