Re-post from the UOA thread, but posting here to get more technical input. Can a Civic be leaking coolant into the oil from a headgasket leak and it not cause compression to go down?
I'm loosing coolant and it's getting into the oil. The only other places might be the oil cooler or some crazy theory on an IACV weeping in some strange space fabric rip...I digress.
UPDATE:
Awkward twist.
A friend that agreed to do the job initially did some compression testing and cooling system pressure testing. The results?
Compression is good across all 4 cylinders, dry and wet compression.
The cooling system holds about 17 psi strong without backing off.
...to top it all off here is the valve-train (first time I've seen it since owning the car mind you, I'm not a mechanic):
http://img37.imageshack.us/img37/7465/1004056k.jpg
http://img6.imageshack.us/img6/6840/1004055m.jpg
http://img39.imageshack.us/img39/5498/1004057.jpg
so.......
Original head or replacement? At least the valve-train? He says it looks too clean for 260k miles. I've only had it for 35,000 miles or so; almost 3 years. The PO claims they did the 3,000 religious oil changes, etc.
So, I don't know what to do. My buddy advised holding off, he was willing to do the job but hesitant b/c of the rest of the data not making sense.
To be fair, this oil analysis was the first with confirmed coolant. Mistake? I do have consumption now that I didn't have before and I don't see it leaking externally(much, I did recently however have a hose that started leaking slightly)...
Does this mean it's the oil cooler? Here's a pic below of the design:
http://www.hondaautomotiveparts.com/auto/jsp/mws/catimgs/13sr301_e13.png
It's about $230 without replacing the center bolt b4 shipping. Not sure about local price on dealers.
To top it all off, now I have the parts for the HG job that might not need to be done. However, with the pics of the valve area...I don't know what to think.
Not sure how to test the oil cooler aside from just removing and replacing. (Maybe run fluid through the cooling passage with it removed from the vehicle and see if it seeps into the oil galleries?)
Lastly, aside from 'block testing' with a kit, he suggested getting the coolant analyzed. Personally, I don't know why the difference. I'd just as soon rent a block-tester kit and confirm if there are combustion gasses in the cooling system. If that's true, and I have coolant getting into the oil where else OTHER than the hg? Could the block/head be warped or cracked from an overheat by the PO that is just now showing? AFTER 3 years of owning with no symptoms and I've never had it overheat?
My head is spinning. Please help. I can't fix both financially, though I suppose pulling the head may confirm if the block/head is warped or cracked at least. Thus, replace those parts anyway since I've got the replacements on hand...and bite the bullet if I need to replace the oil cooler later, changing the oil a bit sooner than I have been(3,000 max until coolant is gone).
LINK to UOA thread:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2655364&page=1
ADDED: So, perhaps take a whiff at the intake past the throttle plate to smell for coolant or just remove the IACV and put water through the cooling passages to see if it leaks into the unit itself...I don't think I'd be able to visually see coolant getting into the oil by removing the oil cooler, since it's a sealed piece and costs $230+ to replace.
So, that's a 'throw a part at it' as well at this point. This is very confusing. Some Civic owners have said they have great compression and coolant loss via other means relative to the head gasket still.
