Tire: General G-Max AS-05
https://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=G-MAX+AS-05
Car: Fiat 500 Abarth
I just replaced all four tires on my new to me Fiat 500 Abarth. Car has roughly 40,000 miles with receipts in the glove box for all maintenance that goes above and beyond the manual including two different alignments. Car tracks perfectly straight, and is simply beautiful to drive on the highway. The new tires were amazing, and some of the best I have ever had on a car...quiet, VERY grippy, track VERY straight. They track so well, even in a cross wind I can take my hand off the wheel for a considerable amount of time before having to make a correction.
Now for the odd...
I got a large screw in the sidewall of my front right. As the tires have less than 3000 miles, I simply ordered a new one, with no concern of replacing a pair, instead of just this single tire (usually if my tires are less than 50%, I will replace a pair instead of just one). Got the tire in, pulled the rim off the car, and dropped them at a local shop on my way to work. Picked them up on the way home, all was good. I mounted the tire with the intention to drive the car to work in the morning.
In the morning, I set off from my gravel road onto the highway and immediately notice the car pulling hard to the right under acceleration. It also won't track straight, with a slight pull to the right under cruise that increases with the addition of torque. Being totally frustrated by the time I get to work, I figure it must either be a difference in the new diameter to such a small car, or a pressure imbalance causing it.
I get back home that night and check the tire pressures...it was about 5 psi lower than the others. As I was fixing it to match, I notice the shop had mounted the tire literally "inside out" with the "inside" label on the outside. I drove the car the next day again with no time to take it back to the shop, and even with the air pressure adjustment, it was still pulling pretty hard (no change). Not thinking that the inside/outside thing would cause the pull was convinced the small change in diameter due to wear was causing the issue.
I take the tire to the shop yesterday to have it flipped. Slapped it back on the car last night, and balanced the pressure once again. This morning on my way to work...car tracks PERFECTLY!!! Once again, she is a beautiful highway cruiser!
I was totally blown away that the asymmetrical tread pattern would have that much influence on the straight line tracking for my car...just crazy!!! Be sure to check your mounting if you get asymmetrical tires!
Now for the odd...
