- Joined
- Jul 15, 2023
- Messages
- 1,437
Oil doesn’t “degrade” in 1-3 years. That’s just silly. Time basically doesn’t matter on these timescales.
That’s not exactly the case. The idea of a mileage/time interval is to approximate the actual degradation of the oil over either or both time and mileage. Weather ultra short trips or longer distances caused it to happen is baked in. Beyond that, the wise manufacturers offer us guidance for severe conditions to shorten intervals. The question on the table is weather oil that has essentially been unused for three years must be discarded because that time has transpired. I say not, but others point out that the oil could have accumulated moisture, or that it has simply degraded over time. Then there are some true zealots who think that you have a hard and fast rule, therefore it should be followed.The reason a time interval is applied is the way the low miles were put on.
if the 1,026 miles were put on in short 3 mile drives - the oil is probably done.
If the miles were put on in 100 mile trips - the oil is probably still in great condition.
It actually does degrade as soon as the byproducts of combustion come into play. So it’s a different scenario for an oil sitting in a sealed container on a shelf for 3 years compared to one that is inside your engine.Oil doesn’t “degrade” in 1-3 years. That’s just silly. Time basically doesn’t matter on these timescales.
24 posts in: Which engine; turbo or not?Have a 2004 Volvo S40 with 35000 miles.
Not exactly is correct - that is why I used the term probably.That’s not exactly the case. The idea of a mileage/time interval is to approximate the actual degradation of the oil over either or both time and mileage. Weather ultra short trips or longer distances caused it to happen is baked in. Beyond that, the wise manufacturers offer us guidance for severe conditions to shorten intervals. The question on the table is weather oil that has essentially been unused for three years must be discarded because that time has transpired. I say not, but others point out that the oil could have accumulated moisture, or that it has simply degraded over time. Then there are some true zealots who think that you have a hard and fast rule, therefore it should be followed.
I put some Mobil 1 0w30 in a beaker and put a flat cover over it. That left the spout area on the beaker uncovered. I then put it on the shelf in the garage away from all natural light and checked back every year. I wouldn't go past 3 years. It noticeably darkened in the first year and by the end of year three it was looking like aged compressor oil. I threw it out after 6 years.
Look it might have been ok, but how much is a yearly UOA vs just a change every couple of years?
Have we seen analytical evidence of oil degrading in a year or is it an IMO thing?
Nonsense.I'm in much the same boat. I put about 500 km or so on the Honda Accord every year and my last oil change was in January, 2022. I used Castrol Edge 5W-20. The oil looks perfect on the dip stick. I even take it on a long drive once a year or so. I'm going to change it as soon as we get a nice day. 3 years is long enough.
heck, we don't even know if it's a 2004 (mitsubishi) or a 2004.5 (ford) Volvo24 posts in: Which engine; turbo or not?
Also, how's the 22 MY old suspension feeling? coolant...brake fluid...just askin'.
