Filter media coming appart due to contact with oil? Maybe it's possible, but I think it would be a much more common thing if it happened much at all. Maybe a better filter quality? To me, I would look at the weather in my reqion and relative humidity and if is garage kept etc. 2000 miles and the oil should still be transparent with a good filter for the Cummins like the Fleetguard Stratapore. Oh say that you have a 2005. I just sold a 2005 and they are really bad for putting soot into the oil, as they have a thrid injection event that tends to soot load the oil. FDon't bother with the Amsiol or synthetic fill, just change at around 5k miles or so, using a good dino oil. I could never get the oil to get clean with the stratapore filter like the mechanical injection and VP44 injected Cummins.
Anyway, if the TBN of the oil is high when new, then I'd be more inclined to leave it longer than a year. Also considering the volume of oil, at the lower RPM of the diesel it will get pumped through less than a 4 liter sump gas car turning higher rpm etc.
At least extend it to a year and a half or something.
As to the adhesives on the filter media, take a look at the current hydraulic excavators and the hydraulic oil temps they run. ie very high, and the filters stay in there for a long time, and don't seem to have issues.
I'm not saying it won't or couldn't happen, just that it's very unlikely.
It's also very convenient for an oil manufacturer to spec a max 1 year life regardless of mileage.
Put it another way... You will likely never know the difference if you changed at mileage only.
I'd focus on changing your stock injectors before they leak and burn your pistons out at around 150k. These injectors need 7 micron filtration, and the Dodge filter is only a 10 micron. The Cummins fleetguard is a 7 micron. The Baldwin PF7977 or something like that is a 5 micron filter.
