since I am a thick guy and there is one of those plastic scoop things under the bumper on our current ride I have to use ramps, pull the drain plug and filler cap cover filler opening with clean rag to keep out bad stuff pull the filter and let all drain then oil new filter gasket and install, replace drain plug, refill with Amsoil, let vehicle down off ramps recheck oil level... enjoy for another year!
ALWAYS USE JACK STANDS IF YOU USE A JACK TO RAISE THE VEHICLE DO NOT COUNT ON THE JACK TO HOLD THE VEHICLE YOUR LIFE DEPENDS ON IT. :no-no:
on our last ride I was able to do it without the need of ramps as it sat a little higher.
