Recently, a topic came up on AcuraZine regarding Honda's OLM system, which is called the Maintenance Minder.
Most owners with the 2.4L i-VTEC engine in the TSX are only getting 3.5k to 5k miles before the display shows < 15% oil life remaining and calls for an A or B service. Same goes for the turbocharged RDX, even though the RDX uses Mobil 1.
On the other hand, owners of the V6 Acura are usually averaging 6-7k between service.
The maintenance minder system has a maximum interval of 10,000 miles for the TL, TSX, and RDX (and all Honda/Acura vehicles).
Is the 4-cyl Honda actually harder on oil than the V6? Or is it because owners of the 4-cyl models are forced to drive them harder in order to extract enough power, and as a result, the higher rpms seen is resulting in a shorter service interval?
Any ideas?
Any ideas?
