Thanks for the heads-up, George! (Add to your list the Honda and Nissan green antifreeze/coolant concentrates, too.
) I got on Fleetguard's U.S. website to do a little sluething. I eventually found and downloaded the product data sheet for Fleetguard ES Compleat Ethylene Glycol Extended Life Antifreeze Coolant Concentrate and it lists the following ingredients:
- ethylene glycol*
- nitrite
- molybdate
- organic acids ["OAT"]
- low silicates
Note, there was no mention of phosphates. I have no explanation for the discrepency from your description unless there're chemistry differences between identically labled product in the U.S. and Canada. I would
hope Fleetguard's website is up to date. Fleetguard does indicate "best aluminum and solder protection", and at that, in heavy-duty diesel engine applications. In an automotive application, the Flletguard ES Cpmpleat antifreeze/coolant may well be a viable alternative to the "usual suspects", but it doesn't appear to be a direct, identical chemistry replacement for the Japanese "recipe". The question for me really boils down to whether it makes economic sense to use this formulation in an automotive cooling system, and whether the only distribution channel is through heavy-duty diesel engine part/maintenance centers.
*Fleetguard produces a companion propylene glycol product. I did not download its product data sheet, so I cannot comment on its suitability or other ingredient formulation differences, if any.
