In my situation, the o-ring is being used as a gasket between two brass surfaces clamped together, with one surface flat and the other surface having a groove to retain the o-ring(Hansgrohe Shower Valve).
I do not know the composition of the o-ring, so I used Silicone grease (Sylglide) as a lubricant by applying a very thin coat on to the flat surface.
Now I have a small leak. The Hansgrohe instructions did not call for any lubricant. Did I err in using the Sylglide?
