Originally Posted By: Oldasco
I think what has contributed the most to new nuclear plants not being built in U.S. now is the tremendous cost to build them... not opposing politicians, environmentalists, tree-huggers, regulators, etc.
Actually those are the reasons why they are expensive to build. The fuels are cheap, the plants operation are not that much more expensive than fossil fuel, but the regulation and all the permitting to "protect" the locals are partly designed to prevent the plants from building in their backyard.
Originally Posted By: Mystic
It is interesting to me that the US military seems to be able to do nuclear power well without a lot of issues. American nuclear powered warships, which have been mostly aircraft carriers and submarines, seem to have operated quite well with no major problems that I ever heard of.
When you have enough cooling (ocean) around you it is much easier to avoid runaway reaction and melt down. The point is, even if you have a melting core sink down in the ocean floor, the water will boil off and take out so much heat that it will gradually cool down enough to stop, after the fuels are burnt out of critical.
Quote:
If civilian nuclear power plants could be built like the military ones and with good site location I would be pretty happy. Of course the military reactors probably are smaller than a typical civilian reactor.
Not trying to be combative here, but you clearly need to read more to know WHY the navy nuclear carriers and subs are fine. Geology degree wouldn't help you here.
Nuclear subs and carrier use fuels that are enriched to a lot higher percentage of U235 than civilian reactors for safety to their crews and the compact core they have. You will not be able to easily get these highly enriched fuel for civilian reactors due to cost and proliferation reason.
Quote:
The Russians did have problems with the nuclear power plant on one of their submarines. They lost at least one other nuclear powered submarine but that accident had nothing to do with the power plant either.
That tells you how important is cooling. Any non reactor related problem in a nuclear plant today that relies on active cooling and active shutdown (needing externally powered pump to pump cooling water) could have problems that a navy reactor doesn't. The worst case a navy reactor could do is sink down to the ocean floor and have the ocean cool it, and even if it leaks, the sea water would kill the reaction and permanently stop it pretty quickly (that's why the Japanese do not want to use sea water early on, it would have scrap the plants entirely).
In my area there are some large coal burning electrical generating plants. When the first one was built there was an accident and some men (I can't remember exactly how many) were killed. But they quickly repaired the damage and went right on operating. And in recent years they have built additional plants. Sure these coal burning facilities put carbon into the atmosphere. But nothing seems to ever go too badly wrong.
The problem with coal is not carbon dioxide, it is the sulfuric acid, NOX, soot, etc into the atmosphere. These causes respiratory problems and if you want to see true examples on how it turns on in huge amount, look at China (Beijing in particular) and how their people wear masks whenever they go outside and almost 200 days a year their air fail the US safety standard. I have a friend who works as a kindergarten principal over there and they would not let their kids to go outside to play 200 days per year.
BTW, if you spread the contaminated stuff in Chernobyl across a large area, you will get much less radiation than the output from your coal power plant emission (coal ash and exhaust air). Look it up, I'm not lying. Coal power plant has a lot more radioactive emission (coal has a lot of radioactive material) except that they are diluted to a point of background noise.
