Originally Posted By: Pontual
As I said before, when you shut the engine down, the oil in the ring pack and turbo bearings, isnt renowed and the spoon represents it, pretty well. Noak only measure oil loss by volatility and the heat show us also the darkening from oxidation. I already did this testings with Mineral oils and Synthetics too, and always got darker oil and residues from it. The sample in the video show a higher resilience than most oils I ever saw.
Given that some additives darken anyway, and you aren't measuring or controlling anything, what exactly do you learn ?
Is the darkening additives or deposits ?
As I've said before on your ring pack theory, as soon as you shut off, there's no more "raging fires" above the piston adding to the heat, it's residual that will make it's way into the cooling system relatively quickly.
Another point is that the residence time in the ring belt in a running engine is tens of seconds, that's almost forever at 250C in the presence of reactive blowby gasses, so worrying about the thermal soaking after shutdown is worrying about a lesser set of conditions.
Anyway, there's an ACTUAL test, with ACTUAL controls for worrying about piston deposits.
http://www.savantlab.com/images/Q1_2014_TEOST_Technical_Brief.pdf
