Originally Posted by skyactiv
Probably a good batch of diesel that happens to have a higher cetane number than what your use to using.
So far this has been over 4 total tanks, for me thats a solid 2 months, im guessing this would be more than one tank for them. I refilled a different Sunoco about 10 miles in the other direction yesterday to rule the station out. Im only going about 8k a year in the GL and 6 in the tdi, so a 500 mile tank in the GL is 3 weeks or so.
Originally Posted by atikovi
At over 800 miles a tank in my Jetta TDI, it will be a while before I can check for you. BTW, you must have a lead foot if 42-43 mpg is all you're getting in that Golf.
Nozzles, tune, exhaust high flow cat, larger 18" BBS RC wheels, and commute of 5 miles wacks it down. Most I know with ALH rarely see more than 45, most with tunes and all are in the 38 range. Not complaining at 200k and no consumption. Going to Maine in a month, 750 miles round trip, cant wait to see what happens on a full highway tank.
Originally Posted by Chris142
Pump calibration off? Your buying more fuel than the pump shows?
Trying other stations to rule this out, but I refueled at a Sunoco about 10 miles in the opposite direction and still hand calculated to 21.8, 482 miles to 22.06 gallons, 3.039 a gallon.
Originally Posted by Cujet
Diesel fuel can be manufactured with varying energy content. Adding biodiesel reduces energy content, but often improves smoothness. Adding kerosene (similar to number 1 diesel in winter) reduces energy content and MPG. Ultra low sulfur diesel contains less energy too.
Energy content is the driving factor behind diesel MPG.
As a general rule, specific gravity (weight) of the fuel is directly proportional to it's energy content per gallon. Summertime diesel can be made with a higher specific gravity as there is less chance of gelling in summer. Put another way: Lighter-thinner-better in cold, but has less energy.
The difference is more than most people realize.
Fuel Oil no.1 1 Gallon 137400 BTU
Fuel Oil no.2 1 Gallon 139600
Fuel Oil no.3 1 Gallon 141800
Fuel Oil no.4 1 Gallon 145100
Fuel Oil no.5 1 Gallon 148800
Fuel Oil no.6 1 Gallon 152400
Diesel Fuel 1 Gallon 139000
Gasoline 1 Gallon 124000
Heating Oil 1 Gallon 139000
Kerosene 1 Gallon 135000
Great info thanks. I do know that Sunoco switched to B5 back in 2012 or so, however I do not know if its like that across the board with other refineries. Do you know the BTU of B5, B10, or higher?
I also remembered I used one tank of Valero after the inital Sunoco run in the TDI, and lost 2 mpg. Im about halfway through another Sunoco refill and again showing 40+, 303 miles to half tank (7 gal) but well see when its time.
